Need to adjust rear hatch latch oer striker
Searched but can't find too much on this. My rear hatch has a rattle and I want to adjust either striker or the latch . before i start removing plastic has anyone done this ? which one or are both adjustable?
Thanks
Thanks
Before you start adjusting this latch I suggest you get some good grease and lube it.
Note that the latch lube should not go on the top of the floor U striker but on the part of the U bar that faces toward the rear of the HHR.
Thats where the latch contacts the U Bar.
SF
SF
Rear hatch
The pillow blocks will tighten it up, but the problem that I have, is that the hatch doesn't pull in enough. I have wind noise in the back seat. I need the hatch to be tight AND seal properly. Any Ideas on that?
Thanks
Thanks
GhstRider
47
Mar 5, 2007 07:18 AM
