Need Help car dead key stuck in on position.
Old Jul 4, 2021 | 10:21 AM
Jim's 2009's Avatar
Checking things as I go, I have headlights, horn and rear hatch release button, nothing else. I have no power to the positive stud on the under hood fuse panel. That has to be a clue of some kind.
Old Jul 4, 2021 | 11:05 AM
Jim's 2009's Avatar
I am getting power to fuse panel under hood and to starter, I didn't have a good ground when checking with my tester. Possibly ignition switch?
Old Jul 4, 2021 | 11:31 AM
Saying it has power or the battery is "good" doesn't really mean much. You need to take some voltage readings and post them up here.
Old Jul 4, 2021 | 11:39 AM
No power to the under hood fuse box, then inspect the maxi fuse in the spare tire well , back by the ground bolt!
It’s the maxi fuse
Old Jul 4, 2021 | 11:48 AM
Jim's 2009's Avatar
Everywhere I check is 12.73 volts.
Old Jul 4, 2021 | 12:51 PM
Ok, then why won’t it start? Something, somewhere is not connected, or is not functioning correctly. Seeing as you where working on the car , then inspect the work area, possibly inadvertently you knocked something loose, a ground wire? Or as you said the ignition switch has failed.
Old Jul 4, 2021 | 02:04 PM
Jim's 2009's Avatar
Almost think a ignition switch, girl at Advance Auto suggested that, if they had one I would have bought it at $36. I was not [size=13px]near[/size] anything working on the rust, front left jacking point [size=13px]behind[/size] the front tire. I suppose there is no way to test that switch?
Old Jul 4, 2021 | 10:01 PM
That is, however, near the fuse block. I wonder if the positive cable runs through that frame rail?
Old Jul 4, 2021 | 10:19 PM
The maxi fuse supplies power to the BCM. Does not have anything to do with the underhood fuse box. However, check it.
None of the wires run in channels; all are under carpet.
Driver side wheel well under the hood is where a main ground point lives.
If this was last century the ignition switch would be directly wired to the starter solenoid. This century the switch is a sensor for the BCM.
Are you using a key with the + in a circle stamped on it?
Old Jul 5, 2021 | 01:12 PM
Jim's 2009's Avatar
Yes
