Need Help car dead key stuck in on position.
Old Jul 8, 2021 | 04:16 PM
  #31
Jim's 2009's Avatar
Your car is outside of the warranty period. There is no need to take it to a Chevy dealer.
There is no where else to take it.
Old Jul 8, 2021 | 04:23 PM
  #32
Originally Posted by Jim's 2009
Just pop rivets.
You welded pop rivets?
Old Jul 8, 2021 | 04:29 PM
  #33
Jim's 2009's Avatar
Originally Posted by UnknownError
Have you tried jump starting it? It is possible that the battery can read good with a multimeter but have a dead cell that won't start the car. AutoZone in my area will take the battery, charge it, and test it and tell you if it is good or not. Do not assume that just because the battery is newish that there is nothing wrong with it. They come with warranties for a reason.
Tried that, it seems I have no power to the ignition for it to even try to start. Only things with power I have is headlights, parking lights (no turn signals), horn and rear hatch release. No dash lights, dome lights or power locks nothing else. Haven't found any help from garages around me. Chevy dealer 30 miles away is the only choice I have unless I can find it.
Old Jul 8, 2021 | 07:30 PM
  #34
#8 and #10 are the 2 fuses that control the Passkey3 security system, which is the system that seems to be activated/inactivated. I think you said the security lock & key icon was lit?
When you removed the trim around the steering wheel you may have upset some wires. BTW, look in your Owner Manual a see where the handy little door to the key unlock button is.
Old Jul 8, 2021 | 07:41 PM
  #35
#8 and #10 on the BCM, that is the interior fuse block.
Old Jul 9, 2021 | 04:53 PM
  #36
Jim's 2009's Avatar
I was thinking maybe the Passkey security system. The icon was lit before everything went dead. I removed the trim after that. How do you correct and inactive security system?
Old Jul 9, 2021 | 05:21 PM
  #37
Your Owner Manual says to put the key in and turn it to reset the security. 2 things set the icon; dead battery and wrong key.
Old Jul 9, 2021 | 05:41 PM
  #38
Jim's 2009's Avatar
I have tried both keys with no luck.
Old Jul 9, 2021 | 06:10 PM
  #39
Ergo dead battery, the power of deduction Watson . At least to get the battery tested
Old Jul 9, 2021 | 07:41 PM
  #40
Jim's 2009's Avatar
Had battery tested at NAPA good, before that tried jumping it with the brand new battery in my truck nothing. Headlights are bright.
