Need Help car dead key stuck in on position.
Old Jul 5, 2021 | 02:36 PM
Jim's 2009's Avatar
Talking to friend of mine and he realized that everything that is working, headlights, horn and rear hatch are things that work without the key on. Everything that isn't working needs the key on. He thinks ignition switch, I will try one.
Old Jul 5, 2021 | 02:41 PM
Then brake lights, power door locks, dome lights should all be working too.
Old Jul 5, 2021 | 03:00 PM
Ok, thanks for letting us know. I’m out.
Old Jul 5, 2021 | 06:51 PM
Check fuses #8 and #10 on the BCM.
Old Jul 7, 2021 | 03:24 PM
Jim's 2009's Avatar
Fuses #8 and #10 are good, ignition switch did not help.
Old Jul 7, 2021 | 03:31 PM
  #26
Jim's 2009's Avatar
Is there a diagram somewhere of all the grounding points on the HHR.
Old Jul 7, 2021 | 03:41 PM
  #27
https://www.chevyhhr.net/forums/how-...cations-56504/
In here
Old Jul 7, 2021 | 05:04 PM
  #28
Jim's 2009's Avatar
Originally Posted by Oldblue
Thanks, I have found about half so far. Talked to my Chevy dealer service manager, no help over the phone. Said they could look at it. Problem is they are 30 miles way and they don't tow. I hate to admit I can't fix something but this has me befuddled might have to find a tow.
Old Jul 7, 2021 | 06:44 PM
  #29
Your car is outside of the warranty period. There is no need to take it to a Chevy dealer.
Old Jul 8, 2021 | 12:54 PM
  #30
UnknownError's Avatar
Have you tried jump starting it? It is possible that the battery can read good with a multimeter but have a dead cell that won't start the car. AutoZone in my area will take the battery, charge it, and test it and tell you if it is good or not. Do not assume that just because the battery is newish that there is nothing wrong with it. They come with warranties for a reason.
