Need to identify part, flexpipe dropped and broke it
Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Spoiler
I have a 2011 hhr 2.2L and this part is broke where dropped flex/converter hit it. Part is cast mostly 1 1/2” diameter with fasteners on both ends. It runs directly above the rear cross member. It has a distinctive # hash pattern. Note pattern on tube Different part but this is where it runs directly above crossmember
Help Identify part broke when flexpipe/converter hit it
I have a 2011 2.2L that has a diecast part directly below the flex joint/converter front connector. It runs directly above the rear crossmember. It has a cross hatch pattern along the narrow center section. Please see photos. Not same part but shows position.
