Need third brake light access
Old Mar 1, 2010 | 07:42 PM
urbexHHR's Avatar
When you're pulling on it, it sounds like it's going to break...and in my case it did....
Old Mar 2, 2010 | 10:42 AM
prod's Avatar
Originally Posted by lockcop
Anybody try replacing the bulbs with LED?
Yeah, I didnt like the LEDs, created "hot spots" and didnt light up as full as the regular bulbs.
Pulling the trim off can break it if not done correctly. Start with one of the outer clips and try to pop them one at a time. If you just grab one side and try to yank the whole thing off, it will bend and break.
Old Mar 2, 2010 | 03:35 PM
Dutchman09's Avatar
I was fortunate. Thanks to this forum I managed to get the third brake light lens off and on without a problem. I found by pulling on one side of the plastic molding, then the other, then pulling straight out from the center, it pops off easily. There are four clips holding the molding in place.
I finally installed the "STOP" overlay along with a Blinking Third Brake Light Module. When you apply the brakes, it causes the third brake light to blink six times before entering into a steady Brake Light ON condition. And if you hit the brake again within eight seconds it will not blink so as not to drive the person behind you crazy in heavy traffic.
Attached Thumbnails Need third brake light access-img_5117.jpg   Need third brake light access-img_5243.jpg
Old Mar 8, 2010 | 06:25 AM
lockcop's Avatar
Thank you prod. Switched the license plate bulbs with LED and really like the white light. Reckon I won't waste the $$ on bulbs for the 3rd brake light.
Old Jun 25, 2010 | 04:45 PM
seanclarke's Avatar
Instead of messing with the brake light, would this also be how to change my rear bow tie assembly?
Old Jun 25, 2010 | 05:27 PM
Talvanos's Avatar
I will be soon, probably this weekend. Where did you get the "STOP" overlay and the Blinking Third Brake Light Module?
NxlKing2304
"How To" Tutorial Library
Apr 10, 2015 12:23 PM
HHR14all
Dec 15, 2014 04:43 AM
jonathanm
Feb 10, 2010 07:53 PM
270weatherby
Dec 5, 2006 01:12 AM
