new clunk
Old Nov 6, 2014 | 04:37 PM
gvander's Avatar
new clunk
Just replaced both front struts and links on my 06 HHR. Car is handling fine and and dull clunking sound is gone when rolling over rough roads or curbs etc. However if I turn sharply left, as if avoiding road kill, then correct back, I hear a pronounced clunk. I actually put original struts back on and same condition. All parts are on correct and torques to spec. I am baffled. Any thoughts?
Old Nov 6, 2014 | 05:31 PM
hagenlmh's Avatar
Drive boot bad?
Old Nov 6, 2014 | 05:34 PM
https://www.chevyhhr.net/forums/prob...g-pop-s-50648/
I bet nobody looked at your Lower Control Arm bushings.
Old Nov 6, 2014 | 05:40 PM
Originally Posted by hagenlmh
Drive boot bad?
??? Say what ?
Old Nov 6, 2014 | 09:50 PM
taz3's Avatar
??? Say what ?
I think he's referencing the axle shaft boot, causing CV joint damage.
It sounds like what is described in the GM bulletin posted in a link above.
Old Nov 7, 2014 | 07:33 AM
Sudden control input to the steering system will cause body roll, so check you LCA rear bushings and the sway bar bushings and end links, I have seen the end link nuts not tightened up and the LCA bushings look fine but fall apart when I removed the arm.
It's not very common for the ball joints to be the issue but possible!
Old Nov 7, 2014 | 08:29 AM
Kind of sounds like a sticking strut bearing. Turn the wheel, then turn it back and the spring binds, then "pops" back into place.
When you replaced the struts, were they quick struts ? If just the strut cartridges, did you replace the bearings ?
Old Nov 7, 2014 | 11:16 AM
gvander's Avatar
Yes, they were quick struts, ie with springs.
11hhrlt
"How To" Tutorial Library
13
Nov 30, 2016 04:08 PM
moonsign
0
Sep 27, 2012 10:53 PM
capp002
11
Jul 10, 2011 05:31 PM
voigtsga
Mar 31, 2011 09:31 AM
cpope84
Mar 10, 2011 11:27 AM
