Newbie adds a Woolly Worm idea & question!
Hello, I just registered, but have been lurking for a few weeks. Glad to be a member!
I was wiping down my engine bay a couple of days ago and saw that my cold air intake hose was degraded and torn in two small places (shocker!). The tears were immediately adjacent to one another, so I decided to try to repair it in place, rather than engage in a full modification right now.
It fits tightly back together, but still needs support to hold its shape. I first thought about buying a 36” x 5” strip of gray wool felt ($8 w/shipping) and tightly wrapping it and clamping it on either end. I also thought of using wool thread ($8 w/shipping; both on Etsy) to sew the new felt onto the extremely tough, existing felt. If anyone wants to try it, you need a thimble and curved upholstery needles (not expensive) to get through it. The degraded areas are thin, though; don’t anchor much of your stitching here or it will tear and make your situation worse. This wouldn’t work for lots of shredding.
However, I also came up with the lazy gal’s option:
steel safety pins, which worked!! But, since I’m an American, I’m itching to add the coup d’ gras and wrap it in heavy-duty, black duct tape. Actually, this is because it’ll look better, keep the pins snugly in place and be air tight. And, so, finally my question: will the tape melt in this area? Particularly on the underside? I know silver foil tape will work, but I really don’t want that hideously ugly stuff under my hood
Thanks!
Dinah
Thanks!
Dinah
Duct tape is fine. Or 3 inch vent tube from the HD/Lowes AC dept works.
Remove the air cleaner and pop the hose out of the hole in the wheel well. It is just a rubber grommet in the hole. remove the rubber end to b reused.
Don't do what most of us have done; try to loosen the clamp on the air cleaner end, the screw is on the wrong side on purpose.
Thanks! I plan to. I just don’t have much time to spare right now and am doing the lickety-split version, which I hope to get away with because my leak isn’t too bad :)
You will need something capable of cutting the steel wire spiral. Wire cutters, saw/ good shears etc.
I wrapped mine in duct tape; Oldblue replace with 3 inch dryer vent.
The tube is not a critical part, the car will run acceptably without it. It is for a slight reduction in the intake air temp. Marginal performance improvemet at best.
