No Heat To The Floor
Old Jan 3, 2013 | 08:36 AM
Originally Posted by donbrew
My 2011 does seem to have a cold floor. If you set it to dash + floor the floor goes to almost nothing. Then when I least expect it the whole car will get hot, the coolant temp stays around 192F while moving, the cooling system is full (now). I need to set the fan on 3 when the ambient is 40F in order to feel any heat to my feet, until that hot wave comes along after 120 miles or so.
The old 2008 was not as bad, but same symptoms.
We apologize for the frustrations on this. Would you like for me to look into this further? I just need your VIN so I can check any applicable warranties or programs. Also a trip to the dealership may be best in this case.
Brandon (assisting Michelle)
Chevrolet Customer Service
Old Jan 3, 2013 | 06:20 PM
I was not actually complaining, just commiserating with the OP. But I will be sending a PM for some info.
Old Jan 21, 2013 | 05:32 PM
Today, I got around to replacing the cabin air filter, which did seem to make a small difference. And I taped up the under seat rear foot warmers, we are expecting a Canadian invasion (Alberta Clipper) starting tomorrow A.M. I'll see if it helps.
Old Jan 25, 2013 | 11:13 PM
Blocking off the rear vents does seem to help. I never have any passengers, so it's okay with me.
sebreece
Mar 2, 2015 07:44 AM
fiveothis
Nov 13, 2014 12:07 PM
Macklady15
Drivetrain (Excluding Engine)
Dec 10, 2013 06:28 PM
cons300x2
South Pacific
Aug 4, 2011 12:50 AM
greg.may12
Jun 11, 2010 10:59 AM
