no power to scanner
Old Feb 11, 2010 | 11:26 AM
rotaryboy23's Avatar
no power to scanner
Kind of a strange problem.
My CEL went on last week. I assumed it was the gas cap, so I tightened it, started the car a few times and it went away. A week later, same damn thing.
So I figured I'd borrow a buddies scanner and see WTF was up. plugged it in and got nothing. No power to the scanner.
I was looking at fuses, but ran out of time this morning. ANybody run accross this before>?
Old Feb 11, 2010 | 12:12 PM
JoeR's Avatar
The OBDII port is on the same power circuit as the front power outlet (aka cig. lighter).
Old Feb 11, 2010 | 12:28 PM
SmootHHR's Avatar
My ciggy lighter was out too. One of the tiny fuses (15amp I think) in the block under the hood. Pop the plastic cover and there should be a diagram and few extra fuses underneath. #29 if I remember correctly
Old Feb 11, 2010 | 02:27 PM
Sno White's Avatar
Your Buddy's scanner may be an older unit without the NEW OBDII "CAN" option.
Old Feb 12, 2010 | 07:47 PM
Yeah, I kinda figured it was a fuse. Got 2 codes out of it...
P0014 Camshaft Position -Timing OVer Advanced or System Performance
P1174 -->Fuel Trim Cylinder balance malfunction.
the P1174 occurred twice...
Any ideas? The P1174 eventually cured itself twice, then the latest one I didn't give much time to let it disappear before plugging it in.
Also, I'm not running premium in the 2.4L... Should I start with that? I heard a rumor they have 2 separate fuel tunes, but that sounds like crap to me...
Old Feb 22, 2010 | 09:56 AM
frey55's Avatar
I have the same problem...All fuses good ..eng light on and no codes just blank screen
Old Feb 22, 2010 | 02:15 PM
Zagohhr's Avatar
Me too... I´ve seen the check engine light on and turn off itself seven times since December. Really annoying. I bought a pocket scanner, but nothing appears, just the blank screen. But is interesting that my cig. Lighter is out. I´ll check the fuse today, and i´ll let you know what is in my case.
Old Feb 22, 2010 | 02:43 PM
ChevyMgr's Avatar
You might want to go to a dealer and get that fixed for free if your's falls into the criteria in the TSB.
https://www.chevyhhr.net/forums/show...=23231&page=11
Old Feb 22, 2010 | 07:46 PM
frey55's Avatar
cig circuit
Thx JoeR...you helped me diag. my problem with scanner. The code was a missfire. P034
Old Feb 22, 2010 | 08:56 PM
Zagohhr's Avatar
You are the man JoeR! I´ve replaced the cigarrete fuse and now i can use the scanner tool! It displays P300.
jay loukakis
Jan 15, 2014 07:33 AM
chevyorange
North Pacific
Feb 24, 2012 12:10 AM
cajunken
Mar 29, 2011 05:50 AM
pstar
Jul 6, 2010 08:25 PM
442dude
2.2L Performance Tech
Jan 10, 2008 07:30 AM
