No tail light, no radio button, no heater control light
Old Mar 8, 2018 | 09:32 AM
  #51
The staples got in the way!
Old Mar 8, 2018 | 09:54 AM
  #52
Cat Man HHR's Avatar
Originally Posted by hollywood23113
This relay is 4 pin.
Disregard the center pin, it's wired the same as a 4 pin relay. The "A' stands for auxiliary terminal.
Old Mar 8, 2018 | 09:57 AM
  #53
Originally Posted by donbrew
The pictures in #45 aren't explicit enough? Gonna have to switch from Playboy to Hustler versions.
Just a little more brain candy if people are interested in how a part works.
Old Mar 8, 2018 | 10:04 AM
  #54
The point was the pin numbers are standardized.
Wasn't aimed at you Cat Man.
If we need to be exact:
(bottom view)
Old Mar 18, 2018 | 10:46 AM
  #55
hollywood23113's Avatar
OK guys I Took it to the mechanic, he unplugged the BCM to check the continuity, it was good plugged it back in everything works as normal now. So all this freaking time it seems like it may have just been a loose connection inside that plug.
Old Mar 18, 2018 | 10:51 AM
  #56
Loose wires a very good candidate!
Old Jun 27, 2018 | 08:34 PM
  #57
Im baaackkkk. The damn problem is still there. As stated above, everything was working after picking it up for a couple days, so I took it back to him. He still couldn't find anything, says he thinks its the BCM, but not 100%. I dont know if I stated this, but he could make them work fine when he touched one of the prongs on the relay with a grounded test light. He told me he did all he knew to do and maybe the dealer could do more. So after 1 hour at dealer, $100, I know more than they do. They checked bulbs, fuses, grounds, relays lol everything I told them I checked. So by a vote, do yall think it is the BCM? What else tells the lights to turn on other than the switch which is new.
Thank you all for the help, but if we can figure this out quick its going to auction, dont want to drop $1000 into it and that is what is gonna happen if the dealer keeps messing with it.
Old Jun 28, 2018 | 08:10 AM
  #58
Loose connections, not the BCM
Old Jun 28, 2018 | 08:49 AM
  #59
If you are willing to bet that one transistor in the BCM has gone bad, go ahead.
If a new BCM does fix it, more than likely it is playing with the wires and connectors that did the job.
Pin 86 on the relay is a signal from the BCM, it supplies GROUND. That GROUND comes from G203 behind left end of the dash. Pin 85 is always hot.
The turn/stop/tail/markers all join together at J403 33CM from the breakout to the right side lights. (I would look here, that is the place people like to splice into for hitches)
Old Jun 29, 2018 | 11:42 AM
  #60
Broken wire between the BCM and the fuse block
