No Voltage at Starter
Old Jul 29, 2017 | 05:27 PM
  #31
The fusible link to the generator is not part of the starting system.
If memory serves, the 50 amp maxifuse near the battery is not part of it either.
Old Jul 29, 2017 | 05:43 PM
  #32
The 50 A maxifuse serves the BCM.
Old Jul 29, 2017 | 05:54 PM
  #33
OK, so maybe it is, but if it were bad, you'd see most other systems not working also, right?
Old Jul 29, 2017 | 08:49 PM
  #34
I was agreeing.
Old Jul 29, 2017 | 10:57 PM
  #35
Originally Posted by donbrew
I was agreeing.
Groovy, man
Old Jul 30, 2017 | 05:59 AM
  #36
petvetdoc1's Avatar
The only thing I haven't disclosed is that my son was reading the multi-meter display while I checked the voltage. This introduces another possibility, of course, but he is pretty reliable.
I will check voltages at other points when I get down there with the new starter. If the positive connection from battery to starter is cables with direct connections on posts at fuse box, it should be easy enough to troubleshoot. Will I need to remove fuse box to check or is connection at positive jump start terminal?
DonBrew, I am in Ruther Glen. We are neighbors. Car is in Virginia Beach. Thanks one and all!
Old Jul 30, 2017 | 07:47 AM
  #37
The battery to fuse box and the fuse box to starter is the terminal at the fuse nor with the red cover.
Here
Attached Thumbnails No Voltage at Starter-img_0434.jpg   No Voltage at Starter-img_0433.jpg
Old Jul 30, 2017 | 08:43 AM
  #38
petvetdoc1's Avatar
Makes sense. Wire below fuse #5
Old Jul 30, 2017 | 10:02 AM
  #39
Hmmmm, I believe we are acquainted! Does my step daughter Patricia work for you?
Old Jul 30, 2017 | 10:58 AM
  #40
petvetdoc1's Avatar
yes, I didn't know you were an HHR guru!
