Noisy transmission
Old Aug 23, 2024 | 08:40 PM
Rthorne's Avatar
Noisy transmission
Hope someone can tell me what's causing the noise. The front-end of my car is loud going down the road. I thought it mite be a front wheel bearing. I removed the front wheels but the bearings are fine. I started the car and put it in gear and there is loud raddeling noise on the drivers side of the transmission by the shift.
Old Aug 23, 2024 | 09:01 PM
to the forums!
Link in my signature for diagnosing noises.
Old Aug 23, 2024 | 10:12 PM
Have you tried having somebody sit in the car foot on brake while you feel for vibration, especially the air cleaner?
Is it only when rolling?
I am guessing either a cracked flex pipe or a broken air box bracket.
To check the hubs: jack the wheel up and pus/pull on the wheel, if you can feel any end play the hub is bad.
Old Aug 24, 2024 | 07:29 AM
Then again it could be LCA rear bushings.
Old Aug 24, 2024 | 10:03 AM
greg8453's Avatar
Noise while not moving? Maybe record it for us.
Old Aug 24, 2024 | 10:06 AM
Find a good mechanic shop.
Old Aug 24, 2024 | 10:58 AM
Damaged upper or rear transmission mount.
Chrisl1059
Jan 13, 2016 08:19 PM
Smoke Wagon
Oct 24, 2014 06:16 PM
fsc44
Aug 29, 2012 02:11 PM
Joepoppa1
Jan 31, 2012 01:29 AM
Owebo
Nov 26, 2008 08:17 AM
