Not an HHR but still a Chevrolet
I don't have an HHR but a Monte Carlo 2003. My problem is sometimes when I use my turn signal, the signal won't come on and I get a buzzing clicking sound, after a while if I leave it on all my gauges peg to the left and then pop back to normal, and all my warning lights flash and then the turn signals work again. Sometimes this issue will kill the engine and I will have trouble starting again. If I slap the top of the dashboard it will start working again. Has anyone heard of this type of thing before?
Last edited by 843de; Sep 4, 2016 at 01:20 AM. Reason: Can't stand seeing Chevrolet misspelled.....
Totally the wrong forum. However it looks like you have some sort of short happening - so tear your turn signal mechanism out and check it for problems, as well as the mechanical flasher that is likely under the dash.
Other than that, you are kinda on your own. Check around for a more suitable forum.
ps: its Chevrolet, not chevorlet
The HHR turn signal system is quite different from the Monte Carlo, so the correct forum would be helpful. Try this one
Monte Carlo Forum - Monte Carlo Enthusiast Forums
HHRmobile
Sep 1, 2010 07:09 PM
muzik4life
Jan 20, 2007 11:19 AM
Lee In Calfi
Sep 5, 2006 07:35 AM
