Observation about Ecotec oil filters
Old Jul 4, 2007 | 03:26 PM
Lone Ranger's Avatar
The Delco and Wix have a smaller diameter opening in the middle vs. the Supertech and FRAM (opening where anti-drainback valve is mounted).
I recently compared a Purolator Premium Plus unit (15436) to the Delco PF457G and noticed the Purolator had the same larger diameter opening as the Supertech and Fram units.
I wonder if this would effect Flow Rate, or if it causes the OEM design (Wix, Delco) to function differently in some fashion vs. the others? The narrower opening appers to be the reason Wix and Delco have the s-shaped mounting rails for the anti-drainback valve.
Old Jul 4, 2007 | 09:59 PM
Goose's Avatar
Not sure LR.....what are you using on this latest oil change?
Goose
Old Jul 4, 2007 | 10:13 PM
AC Delco at the moment. K&N really hypes their flow rate. Tempting, but not for $15.99... K&N oil filters are made by Champion I think, if I remember right from what I read on BITOG. I made a post to that ecotec oil filter thread on BITOG a little while ago, about trying to figure out how these cartridge filters work in the ecotec. It appears as though there is no design intent to try and hold oil in the filter housing once the engine is shut down.
Old Jul 5, 2007 | 06:27 AM
Black Beauty's Avatar
What`s BITOG?
Isn`t the filter/canister mounted above the oil pan, vertically?
How would you expect the oil filter to stay full, and if it did, what amount of pressure would be required to move oil through such a filter?
Old Jul 5, 2007 | 07:57 AM
Goose's Avatar
Originally Posted by Black Beauty
What`s BITOG?
BITOG is Bob is the Oil Guy Forum....
Anti Drain Back Valve is what is used on oil filters to keep oil from draining out of the filter back into the sump..I've never used a cartridge filter before so not sure exactly how this works...I'm sure there has to be some sort of anti drain back as if not all your containments that the filter catches would drain back into your system
Goose
Old Jul 5, 2007 | 08:35 AM
Lee3333's Avatar
My thoughts-stick with the AC/Delco. If, heaven forbid, you have any problems with your engine, you know GM will try to blame something you did. I bought a case of them from my dealer (got a good price) and keep records of all of my oil changes (also using Mobil 1).
If you use a different brand, even though we all know there should be no real difference, GM could blame your problem on using not factory parts.
(Like I am one to talk-with modified suspension, engine and computer, changed stereo, and other electronic add-on's)
Old Jul 5, 2007 | 08:50 AM
Black Rose's Avatar
That seems to be correct. When I check the oil right after the engine is shut off, the dipstick shows the oil at the Max indicator. If I let the car sit for hours, the oil is about 1/4" above the Max indicator.
BTW, when checking the oil, have the indicators on the dipstick facing the engine. Goose made that discovery.
Old Jul 5, 2007 | 01:17 PM
Thumbs up
I did not know this.
Old Jul 5, 2007 | 01:24 PM
Goose's Avatar
Yeah...as you insert the stick back in...let it sort of turn like it wants to....the natural path will be for it to turn over towards the engine. Don't force it to go back in straight like I was doing....if you do that your oil will always read high. Let it just twist and with 5 qts it will be dead on
Goose
dustin6119
Aug 16, 2012 11:57 PM
foolmoon_design
Apr 14, 2011 08:37 AM
mongo
Oct 27, 2010 07:18 AM
Nov 14, 2008 12:02 PM
Lone Ranger
Jul 27, 2007 06:17 AM
