Odometer doesn’t move
This is my 1st post. I purchased a 2011 HHR and the odometer reading is stuck, the rest of the gauges work and I have a few other problems horn won’t work,cruise won’t engage,back windshield wiper doesn’t work .
Deanna Kelly
Seems this is not your 1st post. I saw your other posts where you said you DID have issues with gauges not working.
Maybe fill us in on some car history like model, mileage, how long you've own it etc.
Splitting it between 2 different threads with conflicting info can make it hard for us to try and help you.
Yes, FMG , those posts are #’s 20 and 22 in this thread
https://www.chevyhhr.net/forums/prob...n-62613/page2/
seems there is a loose ground wire under the dash somewhere, Deanna. Or perhaps corrosion.
https://www.chevyhhr.net/forums/gene...vancing-60237/
and
* Turn the ignition to the 'on' position. Place your foot on the brake and tilt the steering wheel down if your vehicle is equipped with a tilt wheel. Shift the vehicle into the lowest position on the shifter.
* Depending upon your model, the instrument panel bezel will be held into place by bolts, screws or clips. If you have clips, you can pull the bezel off the front, but if you have screws or bolts, you will need to use the proper tools to remove the bezel. After you have it off, set it aside.
* Unbolt the gauge cluster and unplug it.
* Replace the gauge cluster with a new one and plug it back in and bolt it back into place.
* Replace the bezel.
* Shift your vehicle into 'Park' and turn it off.
This should take care of the odometer not working. If it does not, you may need to contact your dealership for more assistance. In some cases, the ECM may have a software problem that requires the assistance of a technician at the dealership.
It may be possible that the connection between the wiring harness and the cluster is loose. If you suspect that the cluster is fine, but the connection is bad, you can fix that by following the steps above to disconnect the cluster. You can add white Lithium grease into the connection holes, then wipe the excess grease off the connector before plugging it back in.
Odometers with old-style cables may need to have cables replaced. Check to ensure that the cable is still connected or replace if it is a bad cable.
check the harness connectors
and
Odometer not Working
If only your odometer is not working, then the dash cluster may be the culprit. Should you need to replace it, here are the instructions for replacing the dash cluster. Start by parking your vehicle on a level surface and setting the parking brake.* Turn the ignition to the 'on' position. Place your foot on the brake and tilt the steering wheel down if your vehicle is equipped with a tilt wheel. Shift the vehicle into the lowest position on the shifter.
Could be, again that will involve inspecting the wiring harness and ground wires
https://www.chevyhhr.net/forums/how-...cations-56504/
