Oh boy, did I buy a lemon!
Old Jul 12, 2017 | 10:23 AM
As long as you're changing out the coolant(which requires removal of the thermostat to do correctly), you should replace the thermostat also.
Thermostat - (2006-2011 All Models)
ACDelco 131-158 GM P/N 12622410
And to the forums!!
Old Jul 12, 2017 | 11:59 AM
Yes and don't get roped into going cheap with a Stant or Motorad , they don't open in the time frame parameters the ECM is looking for, also ensure to get the 180 degrees, yes open the box, people do make mistakes returning things!
Been there and had to drive back to the parts palace to get it straightened out, good thing we have 2 cars.
https://www.rockauto.com/en/catalog/...hermostat,2200
Old Jul 12, 2017 | 12:27 PM
J W Davis's Avatar
While your at it....change out the cabin air filter, your breathing all the crap the previous owner had....euk!
Old Jul 12, 2017 | 12:31 PM
Conax's Avatar
Originally Posted by donbrew
GM #12625058 a/c delco spark plug (iridium)
A/C delco # 41-103
Don't try to gap them, they are correct from the factory.
Check the rubber cap on the t-stat housing, they sometimes get a tiny hole and let steam out so you never notice a drip.
I have always double checked my gaps before installing plugs, once in a while one gets dropped.. What is the correct gap?
Inquiring rednecks need to know..
Old Jul 12, 2017 | 12:32 PM
Here's the handy part number list
https://www.chevyhhr.net/forums/comm...-part-i-48833/
And a how to for the CAF
https://www.chevyhhr.net/forums/how-...-change-52300/
Conax, if the gap looks out of whack , return it to get another plug, the wick is fragile and can be damaged easily. I always open the box at the store and check them!
Old Jul 12, 2017 | 12:46 PM
Conax's Avatar
No bending, eh? good to know. I learn something here every day.
Thank you
Old Jul 12, 2017 | 04:31 PM
Touching the iridium whisker is a very touchy thing, they break if you look at them wrong. If the plug got dropped the whisker probably broke.
Old Jul 12, 2017 | 05:01 PM
Conax's Avatar
iridiums, oh.
Thanks!
Old Jul 13, 2017 | 02:59 PM
Scouttster's Avatar
AUTOLITE ( Ford ) Sparky plugs?
BOOOO YEAAAAAA!
Wow!
Runs like a top now. Much more power and acceleration. They kept telling me to go ac delco irdums.. I went Ford..
Any input?
Old Jul 13, 2017 | 03:01 PM
No, input, but Iridium's AC Delco 41-103. Period!
