Oil filter leaks down?
Old Dec 8, 2009 | 10:05 AM
Fred08's Avatar
Hi folks, My chev HHR 08 oil shows over full after it sits overnight. I know I put 5 quarts in it and it checks good when checked after I first shut it down. Any one else notice this, or is it a problem? Thanks Fred https://www.chevyhhr.net/forums/images/smilies/sad.gif
Old Dec 8, 2009 | 10:11 AM
solman98's Avatar
When you first shut it down, it should read a little low. After it sits for a a few minutes, it should read full.
Sounds like you may have overfilled it.
Old Dec 8, 2009 | 10:12 AM
ChevyMgr's Avatar
You have too much oil in the engine. Trust the reading when it has sat a while.
Old Dec 8, 2009 | 10:22 AM
Fred08's Avatar
Thanks for the replys, I wll change the oil and check again. Fred
Old Dec 8, 2009 | 09:22 PM
skyeglen's Avatar
Fred, is it possible that the old oil did not completely drain out and when you added the 5 quarts of new oil it would show overfill? The approach to my barn is a slight uphill angle and works perfectly for getting a complete drain but the 1 time I drained it on the flat floor of the barn itself I didn't get it all out. and it showed a slight overfill.
Old Nov 5, 2012 | 07:34 PM
toolman34's Avatar
ok, old thread, but here is my experience, most oil filters for the ecotec engines have the wrong size o ring on the bottom plug part of the filter(including some ACDelco ones). This allows almost 3/4 of a quart of oil to drain into the pan from the oil filter housing. The dipstick will read way overfilled in the morning, and the engine has to pump up the oil on startup resulting in a few seconds of noise, and extra wear on the motor. Also, if the o ring is really small, you could be losing oil pressure too???? Purulator filters are the only ones I have found lately that have a fat o ring that fits snug in the drain hole.
tylerz71
Aug 17, 2022 07:02 PM
RickyO
Jul 30, 2017 10:06 AM
tunesville
Sep 24, 2013 07:35 PM
gaspergou
Jan 12, 2008 12:36 PM
coolsurf
Dec 27, 2006 01:51 AM
