Oil Filter O-Ring
Doesn't happen too often. Just go buy a new filter with O-ring and replace it. While you have the cap off, inspect it closely for any hairline cracks. If it's cracked, you'll need a new one. They're easily available and less than $20 for a cap,filter and O-ring combo.
1st , look closely though, and make sure it's the filter cap where the leak is from. Sometimes a valve cover leak or other leak can look like the filter cap is the spot.
Kind of a common problem with the LNF. May not be the oil filter cap, mine wasn't, it was nicked o-ring at the cam sensor running down to the oil filter cap.
Look at this thread, 2.0 LNF Engine How-To: Repair LNF cylinder head oil leaks - Cobalt SS Network
Lone Ranger
Jul 14, 2008 07:09 PM
SindyDix
18
Jul 27, 2006 02:21 PM
