Oil leak?
Old Jan 16, 2020 | 08:29 PM
guppy's Avatar
With 150K I would like to suggest that you check your oil level while you are filling up the gas tank. Maybe not needed every time, but once a month for sure. You standing there doing nothing anyways, there is usually paper towels at your conveinence.
Old Feb 24, 2020 | 10:15 AM
slonny's Avatar
I replaced valve cover gasket about 1,000 miles ago, and when checking the oil level today noticed that there was a noticeable leak around PCV hose. The hose is properly clamped. Also there were a lot of deposits in the tube. I guess that is where the oil was going, just like you guys mentioned. Is there anything I can do about this?
Old Feb 24, 2020 | 10:39 AM
Did you wash the valve cover out, I soaked mine from Oldblue’s 2.2 over night in warm water and Dawn to get at the oil and stuff on top of the splash baffle plate. It cleared up the oil in the PCV tube problem.
Old Feb 24, 2020 | 11:29 AM
slonny's Avatar
I did even think that step was necessary. I don't think I want to go through that process again.
I've read that oil in the pcv valve hose is normal, as that's what passes through the hose, oil blowby. Would that mean I don't need to worry about oil in the tube, and just get a better clamp for the hose?
Old Feb 24, 2020 | 11:34 AM
Replace the hose and clamp, you should be just fine, here’s what I determined
https://www.chevyhhr.net/forums/2-2l...ormance-58332/
Old Feb 24, 2020 | 12:17 PM
slonny's Avatar
Thanks for sharing this! I would really love to try oil catch can. I already ordered this one:
https://www.amazon.com/ESPEEDER-Universal-Aluminum-Baffled-Reservoir/dp/B07D8TL35H/ref=sr_1_9?keywords=oil%2Bcatch%2Bcan&qid=1582567306&sr=8-9&th=1 https://www.amazon.com/ESPEEDER-Universal-Aluminum-Baffled-Reservoir/dp/B07D8TL35H/ref=sr_1_9?keywords=oil%2Bcatch%2Bcan&qid=1582567306&sr=8-9&th=1
Following your suggestion, I will just need to get several feet of 3/8 ID fuel line to set up one of these. It seems like you did not even bother with hose clamps in the setup on the bottom. Did zip ties work well for you as far as durability goes?
Old Feb 24, 2020 | 03:51 PM
There is no pressure, so zip ties work great
Old Feb 24, 2020 | 08:42 PM
I check my fluids pretty regularly.
Don't forget to check your engine coolant in the reservoir tank, I check this cold..
My coolant level was down by 1 ounce. (I am also a lil fussy about fluids being precisely on the full mark, which I marked on mine back in 2009 )..
Then the brake fluid level in the master cylinder.
Windshield washer fluid reservoir.
Old Feb 26, 2020 | 01:30 AM
slonny's Avatar
Just finished installing oil catch can. I think it took me longer to clean all this junk up than to install the can. After seeing this, I think these cans should be mandatory.
This is the setup I used to install it. I used 1/2 in tubing. 3/8 in was too small.
Thanks, Oldblue, for pointing this out.
Sleeper, every time I check my coolant, it is always low. I have no idea where it goes. I fill it up in the reservoir up to the full mark, and it then just goes down all the way to the bottom and stays there. No leaks.
Old Feb 26, 2020 | 07:23 AM
Maybe no external leaks but a head gasket issue and the coolant is burned off in a combustion chamber.
Plug the spark plugs and look for one or two that’s different from the others
