Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Very close tolerances. Not supposed to machine the head, don't know how you could screw the deck up. You might find a machine shop that would think about it, a new engine would probably be cheaper.
Hey all, I'm back again. I bought an extra engine to swap into the car so that I don't have the car sitting in the garage too long. I picked up a 2007 cobalt block with ~50k miles on it and started rebuilding it yesterday. The pistons were very dirty but cleaned up well. The bearings look almost brand new. I'm considering replacing them anyway since they're only $25 for a set.
The only concern I have is with the cylinder walls. There's a little bit of surface rust on the walls. I'm used to working on linerless aluminum blocks, so I'm wondering if the bore is fine or if I should ball-hone it? Maybe I should just hit it with a light gray scotch brite?
45 is the correct angle. You are around 30. To stretch them out you need to increase the rate at which you plunge and pull the hone. It's best to practice until you find what works for you.
