Oil leaking into Coolant
Old Apr 9, 2025 | 10:34 AM
  #231
tr34's Avatar
I doubt the manifold has experienced extreme overheating. I looked previously during installation and couldn't see any cracks, but the gasket might be the issue. I don't know how it took me until now to notice the gasket wasn't right. I ordered a new manifold and should have it installed tomorrow. I'll let you know if that fixes the tapping noise
Old Apr 9, 2025 | 11:40 AM
  #232
This in the yellow circle appears to be a crack
Old Apr 9, 2025 | 11:48 AM
  #233
It might be the gasket is upside down, that part number fits the 2.0 ,2.2 and 2.4
I don’t see how it can be upside down, but check your work, match it to the head and the exhaust manifold
Old Apr 9, 2025 | 12:57 PM
  #234
I didn't mean engine overheating; I meant like raw fuel in the exhaust gas igniting (which would likely melt the cat).
Old Apr 9, 2025 | 07:41 PM
  #235
tr34's Avatar
Oh okay, that makes sense. I pulled the manifold off, and I didn't see any noticeable cracks. I also shined a light inside to see if any cracks were visible, but I didn't see anything. It also looks like the manifold gasket may have worked. I think the extra portion of the gasket may be possibly making the tapping noise?
Old Apr 10, 2025 | 07:43 AM
  #236
Looks like you can cut away the excess gasket material. Block sand the exhaust manifold surface to make sure it’s flat!
Old Apr 10, 2025 | 09:14 AM
  #237
PulpFriction's Avatar
Tiny exhaust leaks can sound like tapping. Warpage can cause problems with proper gasket seating. Double gaskets is an old trick that might work or might cause later leaks.
With the manifold off, it’s pretty easy to check if the mounting surface is flat.
Old Apr 10, 2025 | 09:42 AM
  #238
**Deleted**
Old Apr 10, 2025 | 10:02 AM
  #239
In post #231
Old Apr 10, 2025 | 03:05 PM
  #240
Said he ordered a new manifold a few posts back.
What’s yer point? He also said he took off the old one and couldn’t detect a leak. He should want to at least try to detect a problem with the old one if not return a possibly unneeded new one.
