Oil light is on after change
Old Dec 21, 2019 | 03:51 PM
HisAndHearse's Avatar
Originally Posted by Cat Man HHR
Do you have the check engine light on when the engine is running ?
If so and someone has a code reader you might have fault code P0521 which would indicate a bad oil pressure sender.
or the wiring to it.
No, the check engine light is not illuminated. And today I took the car to the store and the oil light did not come on. So now I'm really confused. LOL
Old Dec 21, 2019 | 04:06 PM
I’m thinking loose oil pressure switch wire or failing oil pressure switch , an excellent how to thread
https://www.chevyhhr.net/forums/how-...ng-unit-57962/
Old Dec 21, 2019 | 04:50 PM
Wow. I guess suggesting not to drive the car and getting it looked at was just ignored. Let us know how much a new engine costs you if that one decides to blow up from no oil pressure.
Old Dec 21, 2019 | 06:00 PM
Yes, and are you thinking a new long block or used pic a part engine?
gio89kid
2.4L Performance Tech
23
Jan 19, 2019 10:43 AM
Vera234
Feb 3, 2018 12:05 AM
vettman
Jun 3, 2017 12:29 PM
Majik01
Oct 4, 2014 07:34 AM
bertoswimmer
Aug 9, 2014 09:02 PM
