Ordered new door actuator, how can I keep the door shut in the mean time?
Old Nov 11, 2018 | 05:20 PM
I did not specify 3M; but they do have 5 different blue painter's tape. https://www.scotchblue.com/3M/en_US/...painters-tape/
http://multimedia.3m.com/mws/media/1...face-guide.pdf
Here is one, STIKK brand:
Amazon Amazon
Product description
Blue Painters Tape is a multi-use tape featuring a specially formulated, medium tack adhesive. This works for textured and semi-rough surfaces which gives the tape the tackiness it needs to adhere to your surface but still allows for clean removal for up to 21 days. If not overheated, your surface will be damage free and clear of residue. Blue masking tape is also UV resistant, so it can be used for both indoor and outdoor applications.
Please NOTE: Surfaces must be clean, dust free, and dry before application. While the surface of the tape is moisture resistant the adhesive is definitely not. The adhesive is pressure sensitive and heat activated. Make sure you really press it firmly into place when applying and get it as warm as possible in the room to secure the adhesive. The dryer and warmer the installations are, the better the adhesive will attach.
REMOVE ASAP! The adhesive in painters tape is known as semi-permanent removable. If you leave it on for over a month then you will have great difficulty removing it. It will tear and leave residue behind.
Old Nov 11, 2018 | 08:28 PM
tiapetra's Avatar
Again, the directions for this?
Originally Posted by donbrew
Some blue tape turns permanent after 48 hours. read the directions.
Believe me! The hard way.
Old Nov 11, 2018 | 08:42 PM
Pretend there are qute marks around the quotation with the highlights or go to the links provided to the original sources.
I will add quotes .
Old Nov 13, 2018 | 06:26 AM
tiapetra's Avatar
Still waiting to read where you came up with the 48 hour thing.
Old Nov 13, 2018 | 08:02 AM
That was bad memory, probably.
Old Nov 13, 2018 | 08:05 PM
tiapetra's Avatar
Old Jan 10, 2019 | 04:24 PM
ledbthand's Avatar
On the off chance that someone stumbles across this post a couple years from now looking for a similar answer, I just wound up parking close to the fence, so the door couldn't be opened on that side, by anyone looking for a free radio , and drove the bike around for a couple days. Never really came up with anything better than that.
Lethal Tendencies
Nov 8, 2018 01:54 PM
hhrumadbruh
May 19, 2015 04:50 PM
Mowgli
North East
Jul 19, 2010 06:02 PM
RUDEINC
Oct 8, 2006 07:08 PM
SIHHR
Oct 7, 2006 10:43 PM
