Overheated Cooling Fan not kicking on
Old Sep 22, 2011 | 09:10 AM
Chevy13's Avatar
Originally Posted by donbrew
After you fill the reservoir, it may take a few cycles to suck the fluid into the system. If by low you mean less than an inch in the reservoir, then it was empty! You may be wanting to remove the pressure cap (after the motor is COLD) and check the level there, you should see lots of fluid in the pipe.
You must check the fluid level more often than you used to, the stuff evaporates!
Ive driven it 4 days now with a full cooling system and it's still doing the same thing at slow speeds and idle. I'm going to check the fan this weekend and try to troubleshoot a few other things hopefully
Old Sep 23, 2011 | 12:10 PM
camaro98z28's Avatar
My cooling fan went out on me. I only have 42K miles.. F This vehicle!!! Cooling fan assembly... FML
Old Sep 23, 2011 | 12:35 PM
Chevy13's Avatar
$65.00 on eBay. No need to get upset
Old Sep 23, 2011 | 12:38 PM
https://www.napaonline.com/ShoppingC...firmation.aspx
Old Sep 23, 2011 | 01:13 PM
Chevy13's Avatar
Dead link
Old Sep 23, 2011 | 01:15 PM
  #26
Chevy13's Avatar
http://cgi.ebay.com/ebaymotors/06-08...item1e671c5042
Old Sep 23, 2011 | 01:20 PM
  #27
The problem is will it would on an SS? Im not sure what the difference between all the HHR's are. Anyone know?
Old Sep 23, 2011 | 03:35 PM
  #28
Chevy13's Avatar
There are alot like it on eBay for around the same price. I just searched HHR SS fan
Old Sep 23, 2011 | 03:36 PM
  #29
Chevy13's Avatar
I still cant find which fuse/relay works mine. Everyone says #40 and #50, even my manual does. But they are both empty on mine and even say empty under the fuse cover
Old Sep 23, 2011 | 04:47 PM
  #30
OK I got it back from the dealer with a surprise. Yeah they said is was the Cooling Fan Assembly but says wires melted. Well it's not wires, its the connector that run into the Module thats attached to the fan. Can't figure out what it actually is but it's attached to the fan motor area. I think that burned up and not the fan motor. I might have to bypass so the fan works
