Overheating-Not Thermostat Related
Old Feb 3, 2014 | 03:48 PM
  #31
questgraves's Avatar
Originally Posted by badassbowtie
I got one more stab at this...
so get the car warmed up ( as best as you can) and try to follow the coolant path...once its up to temp and the thermostat opens, all the hoses in line should warm up. considering how cold it is, you might be able to spot where the hot coolant isn't going, by carefully touching or grabbing the hoses.
Its hard to explain but the two radiator hoses (in and out) can tell you alot if they are warm or cold...
good luck to ya
This is how I figured it out. Great idea!
Old Feb 3, 2014 | 04:54 PM
  #32
Originally Posted by questgraves
Well guys here goes... Turns out I did a really bone headed thing and somehow forgot to remove the cap from the lower radiator hose hole. When your done laughing please accept my apologies for eating your time. Thank you all for the help:)
Ooopsie!
Old Feb 3, 2014 | 05:24 PM
  #33
Whew. That one never even entered my thoughts when we were trying to help you figure it out. I've changed out many radiators back in my mechanic days. Luckily I guess, the reworked radiators we used(those all metal ones) never had any protective covers on the inlet/outlets. I can see where a oopsie could possibly happen. It's just unfortunate that the oopsie was done by you.
Just be thankful that the car did not severely overheat while you were trying to find the "problem". It would have been a cra**y day if it had caused any heat related damage.
Old Feb 4, 2014 | 10:34 AM
  #34
better a small error like this than a cracked block or cylinder head!! Enjoy the heat !!!
mjb1965
Jul 7, 2016 01:24 PM
DwHhr2LT
May 4, 2012 08:31 AM
jima59
Feb 1, 2012 07:54 PM
krooozn
Jan 6, 2008 06:11 AM
ng8650
Jul 16, 2006 07:16 PM
