P0011 code-Running by the gurus
Old Aug 15, 2018 | 03:41 PM
gchapell's Avatar
Thank you. I did see Amazon selling them but was surprised to see Rock Auto not. The GM Direct boys et al have them for 33-35$(+shipping). Amazon has the 2 day prime shipping. Thanks for the heads up.
-g
Old Aug 16, 2018 | 03:05 PM
Doc brown's Avatar
One thing I've noticed about Rock Auto is that you can literally look up parts one day and see specific brands, then 2 days later some aren't there. If you wait a week they will probably be there again.
Amazon can be a good source but they don't have everything either.
Old Aug 17, 2018 | 01:19 PM
Andy Cobb's Avatar
Originally Posted by Oldblue
While you’re at it change them both the intake and exhaust Solenoids.
The part numbers are in our how to section.
I used these for my daughter's 2010 2.2L Cobalt, which is the same engine as the 2.2 HHR. Work great, absolutely no issues either installing or use after about 7 weeks.
Amazon Amazon
Old Aug 17, 2018 | 01:21 PM
That’s a great deal.
Old Aug 20, 2018 | 07:12 PM
gchapell's Avatar
Replaced both intake and exhaust solenoids with Gates brand, have a lifetime warranty and were reasonably priced from Rock Auto. Of course they were made in china, whatever. Went to start and would run for 1-2 seconds and die just like before. Tried pushing pedal to floor and it would run for 3-4 seconds. Did this 6-10 times and it finally stayed running and smoothed out fine. Called it a day and no test drive. Went out today, it started fine and went on a 20 mile drive and all seems good. I guess it needed "priming" to get the valves/solenoids pressurized again with oil. Was thinking I should replace the fuel filter too but apparently there isn't a separate one(There is on the cobalt though-supposedly same platform). Thank you for your advice. Now to seal the deal with an oil change. Got a new Wix air filter. Guess what.....Made in China!
-George
gag
Apr 12, 2024 07:13 AM
DASH0071972@
23
Jul 1, 2015 12:31 PM
Sno White
Oct 3, 2012 07:05 PM
bigboss2010
May 23, 2012 01:02 PM
mroney
Aug 23, 2011 11:21 PM
