P0017 Cam Position has ne stumped
Old Mar 14, 2018 | 01:29 PM
The listing on gmpartsdirect is odd, disregard what I said about being the same.
I don't know if the are stamped with markings, they usually come pre assembled on the head.
I listed the gears because that is what I am suspecting. They have a thingy in them that can be done wrong.
Old Mar 14, 2018 | 01:35 PM
uluz2a6's Avatar
Often GMpartsdirect often has poor information. You would be better off contacting local dealership with your VIN to obtain good info
Old Mar 14, 2018 | 02:17 PM
Often the local GM parts dept has bad information too. I point directly at ball joints for the SS. The drawings in gmpartsdirect are the misleading part; they have 2 drawings, one for intake and one for exhaust, but in both drawings both camshafts are identified as #11. The part listing does have different part numbers.
Anyway, here are the specialized bits for installing the cam gears.
Old May 25, 2018 | 03:30 PM
uluz2a6's Avatar
Solved
After refusing to give up (and the absolute NEED for the car to pass SMOG), I finally figured out and repaired this code! I read every service bulletin I could find from GM and came across one that was my exact issue. The cam trigger ring (opposite end of cam as timing gear) is pressed on without a key-way. In some situations this ring can move from its intended position and give the sensor bad intel. That is what occurred in this case. I admit I was hasty and threw unnecessary parts at it, but I was desperate and was also positive cam timing was precise. Also there is a video posted on youtube.com where a shop diagnosis the same issue on a 2.2 Cobalt if you want to see the data in real time on a Tech 2.
Thanks for all the PM and posts trying to help me with this.
Old May 25, 2018 | 04:41 PM
Awesome, glad you got it figured out!
Old May 25, 2018 | 04:45 PM
  #26
uluz2a6's Avatar
Me too! I was so frustrated and customer was about ready to crush me like a bug. It was only off enough to set the MIL, but not off enough that the ECU couldn't compensate for the discrepancy. That's why still ran so well I guess.
Old May 25, 2018 | 06:17 PM
  #27
Just like in post #2.
macgyver6046
Jan 25, 2018 01:56 PM
Smurphy702
Dec 20, 2014 05:10 PM
spike1965
Apr 2, 2013 12:04 PM
RicT
Sep 10, 2012 05:30 PM
alw
Feb 21, 2010 11:18 PM
