Test procedure for cam position sensor?
Most mechanics will just substitute a known good one. Some cam / crank sensors are nothing more than a coil of wire wrapped around a magnet, and can be tested for continuity with a meter. Since many cars will still run with the cam sensor disconnected, you could observe the output of the sensor with an oscilloscope.
