P0171
Yes, that one is normally open, closes to seal. The 2007 I just got, both the vent and purge were bad. The Vent valve clicked but it didn't seal.
Ok, I'll give those a try after work today. After i hear the click will i be able to tell if It seals or not? Can you hear air getting through the valve if it doesnt close all the way? And I'm borrowing a fuel pressure gauge today too So I'll be able to check if it's getting enough fuel. Thanks for the help guys.
Save the old rubber grommet!!!!!!!!!!
Did you specify the year of your car? Some need a pigtail that is included with the part, if you buy it separately it is expensive.
https://www.ebay.com/itm/NEW-Evap-Ca...MAAOSwE45crQGS
So i got the new vent valve and of course it had the wrong wire harness, and completely different plug. Now i have to go to chevy to see if i can find the right one or splice the old connector onto the new unit which i dont really want to do because the other parts store was at a loss. In the meantime, My dad had mentioned the temp sensor could possibly be making it struggle to start and throw the lean code. What do you guys think? And do you have a link to the specs of the temp sensor so i can test it with a digital multimeter?
But why would you/he think that ? Are you getting some abnormal temp readings or CEL's that are temp related ?
