P0171 help.
Old Jun 3, 2015 | 05:21 PM
However, since you cleared the codes it may take several weeks for all of the monitors to run again. Don't be shocked and amazed when the CEL comes back.
A pending P0301 will not set a CEL usually.
Old Jun 3, 2015 | 05:46 PM
bursjon's Avatar
lol. thanks for the vote of confidence lol. I think the misfire is what caused the running lean, and with the new plugs it is running smoother so "Hopefully" all fingers and toes crossed that was it, :)
Old Jun 3, 2015 | 06:41 PM
Your reader may be able to get the number of misfires per cylinder, that would be helpful. The computer allows some in a several drive cycles before setting a CEL.
Old Jun 3, 2015 | 09:56 PM
The lean condition could be what caused the misfire - not the misfire causing the lean condition (misfires should result in a rich condition due to unburnt fuel). And I believe cyl #1 is the last one at the end of the fuel rail.
Old Jun 4, 2015 | 11:13 AM
bursjon's Avatar
well I will have to see in a few weeks what happens. since the weather is getting nice i don't drive it much, i prefer my 650-Vstrom.
Old Jun 7, 2015 | 09:35 AM
bursjon's Avatar
So was out yesterday and the same code came back. thinking about taking it to a shop, plus my transmission started shifting really rough in the first 2 gears.
Old Jun 7, 2015 | 01:24 PM
You have air getting into the system somewhere between the MAF and the #1 O2 sensor. That is assuming that you already checked the fuel pressure, it could be the fuel pump.
That would be a vac leak (the EVAP valve under the hood, probably) or a hole in the exhaust (flex pipe).
the EVAP valve can be tested easily by disconnecting the electrical and both air tubes to it, then blow through it. Free flow of air is bad. New part from AutoZone is about $18.
Old Jul 14, 2015 | 06:22 AM
bursjon's Avatar
So it was not the plugs after all. The misfire was caused by a faulty injector and the lean code was caused by the injector O-Rings not sealing and sucking air. If i sprayed them his brake cleaner the engine would almost stall. I put new O-Rings on and no more code and the transmission is shifting smooth as well. It's amazing how much havoc a vacuum leak can cause.
Old Jul 14, 2015 | 07:45 AM
I'm glad you found the cause of the problem, that sucked!
Old Jul 14, 2015 | 07:49 AM
bursjon's Avatar
Ya. But glad it's all sorted out now. Now I get to start doing appearance modifications :) Just got my new rims and tires last week. Now to LED interior and LED brake and signals....
Mrdjc
Aug 6, 2016 01:16 AM
MrDeadCthulhu
Jul 19, 2015 06:19 PM
donbrew
Jan 26, 2014 06:45 PM
jimpennjr
Dec 4, 2013 05:08 PM
bd20
Jul 9, 2013 07:44 PM
