P0172
Old Jan 20, 2022 | 06:52 PM
  #111
You are supposed to start the car, pull the fuel pump fuse #13 ( I think) let the engine stall to relieve the pressure, then screw on the gauge. To avoid fuel spills or fire!
Old Jan 20, 2022 | 07:59 PM
  #112
Blownz's Avatar
Wonder if that had anything to do with my readings?
Old Jan 21, 2022 | 02:14 AM
  #113
PulpFriction's Avatar
Check. The. Ethanol. Percent.
Sheesh. This is so easy to do.
Old Jan 21, 2022 | 05:48 AM
  #114
Blownz's Avatar
I have no one to check it anytime soon and it’s extremely rare that’s the issue. Did research and only a handful of cases on GM flexfuel vehicles maybe five people including you and OP.
Old Jan 21, 2022 | 06:05 AM
  #115
It’s a very remote possibility, I would still get a different fuel pressure gauge and retest the fuel pump.
Old Jan 21, 2022 | 09:47 AM
  #116
Yes, check the fuel pressure again, but... I'm tending to agree with PulpFriction, because you said you had to "pump the gas". Holding the accelerator pedal down is flood clearing mode. I would think pumping would be a much less efficient way to clear a flooded condition, but would help a little.
Or perhaps the injectors are leaking fuel into the ports. Would that leakage show on the fuel pressure test?
Old Jan 21, 2022 | 11:38 AM
  #117
Injectors are after the fuel pressure test port, but if they are leaking they would reduce pressure. Then it’s either the injectors leaking or the fuel pump pressure regulator leaking. Both are tested with the fuel pressure tester. How fast it leaks down after you turn of the key.
you can clean the injectors reinstall and test again. If the pressure leaks down slower, then it’s the injectors leaking
Old Jan 24, 2022 | 10:14 AM
  #118
It may be rare but I and another member here had virtually identical symptoms under very similar circumstances and we both had a ridiculously high ethanol % setting and both fixed it the same way, by resetting the ethanol%.
It is stupidly easy to check. I did it with a Bluetooth dongle and a free app. Also there was another case with a Facebook owner who had the same problem and “couldn’t” check the %, but I told them to dig into the menus and voila, they found it, it was way high, they reset it and problems solved.
So not so remote under these circumstances.
Also, any parts store scanner should be able to do it.
But, go ahead and ignore me and chase your tails. How’s that gone so far?
I had an extensive PM exchange with the OP Blownz explaining what worked for me, but he feels fine thinking it’s unlikely because the experts here do, apparently.
I’m not saying ethanol % is the problem, I’m saying I have experience, documented here, that says it could be, and it’s really easy to check. Unfortunately, the car seems to try to gradually try to correct itself, so if it ever does, you’ll have replaced half the car and never learn what was wrong.
https://www.chevyhhr.net/forums/prob...20/#post906992
Old Jan 24, 2022 | 11:22 AM
  #119
I’m not doubting nor ignoring your thoughts, Pulp . Perhaps for future reference you could make a tutorial for this procedure.
I scrolled back several pages, and saw you took your car to a dealership for the ECM reflash and they reset the alcohol content.
This isn’t something so simple to do then , someone mentioned a dongle and a free app.
Sorry, I’m at the hospital right now with Sweetie starting her 3rd round of chemotherapy, could you, post the procedure in a how to, or post it here and I’ll move it later. Thanks
Old Jan 24, 2022 | 01:02 PM
  #120
Blownz's Avatar
Sorry to hear that blue! I have only spent $20.00 by the way PF so I’m not wasting money and a dealer/shop wants about $200.00 just to scan.
