P0172
Old Jan 20, 2022 | 03:20 PM
  #101
Blownz's Avatar
Shows nothing with key turned to run. Starting the engine it stays at 57-60psi. Without the engine running what would it mean if I have no pressure?
Old Jan 20, 2022 | 03:23 PM
  #102
After shut of does it drop pressure quickly or more then 5 minutes?
Old Jan 20, 2022 | 03:41 PM
  #103
Blownz's Avatar
The fitting is kinda iffy. If we put the fitting from gauge on to tight it won’t read pressure. If we keep it alittle looser it picks up pressure. When I start it immediately it gets to 60psi. When I shut the engine off it drops to 10 psi pretty quick then stays at like 5 psi. This is with key off. I let the engine run for 30mins and also drove it around for 10-15mins after new MAF and no starting issues or check engine light so far.
Old Jan 20, 2022 | 04:29 PM
  #104
Drops to 10 psi quickly
Start engine, stop engine, pressure should read 50-60 PSI, if it drops more than 5 PSI in 1 minute you need a new pump. Should never be zero.
Old Jan 20, 2022 | 04:37 PM
  #105
Blownz's Avatar
Could be a pump issue but still getting both codes. Like I said we had to use this elbow fitting to connect to fuel rail then the hose fitting to that. If either were screwed to tight nothing happened. If we loosened them alittle pressure would jump to 60psi with it running and stay there. With engine completely off and key it dropped steadily. With key to run position the same. But started right up fine a ton of times and you can hear the pump. Taking MAF back since light just showed up again. No way it could be a leaky injector or bad one? I want to test ohms on VVT solenoids and figured I would pull plugs too and see if one is really soaked in gas or any of them.
Old Jan 20, 2022 | 04:50 PM
  #106
Ok, let us know, the fuel pressure tester should screw onto the schrader valve on the fuel rail
That black plastic cap covers the schrader valve
Old Jan 20, 2022 | 05:03 PM
  #107
Blownz's Avatar
Yeah thanks I know where it screws onto when we screwed it on there right away it started spraying gas. So we took it back off and we tried another fitting and it worked a little better but would leak and then if we put it on real tight it wouldn’t read any pressure . So if you untightened it a tiny bit it would stop leaking after seconds and then start reading pressure. This was from advance auto parts so maybe just the gauge set up didn’t work good for my car I don’t know.
Old Jan 20, 2022 | 06:17 PM
  #108
Blownz's Avatar
Did you ever get a chance to look over the video? Hope your visit went oof with lawyer.
Also how does one know for sure it’s the pump and not the regulator or pressure sensor.
Old Jan 20, 2022 | 06:20 PM
  #109
The regulator and pressure sensor is in the pump , not available separately.
I suggest trying another pressure gauge, just in case that one was messed up
Old Jan 20, 2022 | 06:28 PM
  #110
Blownz's Avatar
Probably just buy the one we talked about as that was my thoughts gauge could have been dropped before. We both couldn’t believe the hassle to get it connected to the fuel rail. Rail had a ton of pressure sprayed all over. Not the best thing inside the engine haha.
