P0172
Old Jan 13, 2022 | 11:17 AM
  #51
Thanks for the update.
Old Jan 13, 2022 | 11:24 AM
  #52
Blownz's Avatar
Your welcome! Just not trying to throw parts at it. You ever hear of the valve cover port getting clogged up before? Wish I could spray something in it to see if that would work. But air hose nozzle didn’t do much like I said and got stuffed up again. That’s exactly why it stutters for a few seconds upon start out just like a hose loose.
Old Jan 13, 2022 | 12:39 PM
  #53
I had a friend here who run a quart of Marvel mystery oil thru until his next oil change , that cleaned it out!
Old Jan 13, 2022 | 01:30 PM
  #54
Sounds like your thermostat is stuck open.
Old Jan 13, 2022 | 02:16 PM
  #55
Blownz's Avatar
Blue so he had no vapor coming out of the valve cover port?
Yes could be thermostat as well.
Old Jan 13, 2022 | 02:43 PM
  #56
Blownz's Avatar
RJ even in cold temps and driving for a short distance the engine should see 180 quickly? I’ve never paid attention to how quick the temps ever got up in the past.
Old Jan 13, 2022 | 03:03 PM
  #57
No , no vapour.
My 2.4 takes about 10 minutes to get to 180 degrees when it’s 24 F outside.
Old Jan 13, 2022 | 03:07 PM
  #58
Blownz's Avatar
I just took radiator cap off and started it and no coolant flowed so it’s not a stuck open thermostat so could be staying closed maybe. But dang if it heats up in 10mins then that’s a issue with mine for sure!
So sounds like I need marvel oil and a thermostat.
Old Jan 13, 2022 | 03:54 PM
  #59
An AC Delco 131-158 180 degrees thermostat! And fresh Dexcool 50/50 mixed!
Old Jan 13, 2022 | 04:09 PM
  #60
Blownz's Avatar
Okay that’s the thermostat I was looking at. Check your email!
