P0172
Your welcome! Just not trying to throw parts at it. You ever hear of the valve cover port getting clogged up before? Wish I could spray something in it to see if that would work. But air hose nozzle didn’t do much like I said and got stuffed up again. That’s exactly why it stutters for a few seconds upon start out just like a hose loose.
I just took radiator cap off and started it and no coolant flowed so it’s not a stuck open thermostat so could be staying closed maybe. But dang if it heats up in 10mins then that’s a issue with mine for sure!
So sounds like I need marvel oil and a thermostat.
