P0172 Code- Help Please
Old Jul 25, 2018 | 10:43 AM
cturboaddict's Avatar
Originally Posted by aradmahogany
If your scanner can monitor live data, I would monitor the O2 voltages, A/F ratio, and long/short term fuel trims to be sure it is running right. If you see negatives in the fuel trim, that indicates a rich condition the car is compensating for, and positive numbers mean lean. You always want to be more rich than lean. Threshold for code setting is -25 or thereabouts for fuel trim rich condition. Numbers are a representative of the percentage of fuel being added or taken away to achieve that yummy 14.7/1 air fuel ratio.
Unfortunately, I don't think my Innova 3100j does live data.
Old Jul 25, 2018 | 11:25 AM
Then , just drive it and enjoy the ride! If the CEL comes back on , let us know!
Old Jul 26, 2018 | 04:49 PM
Womp womp code returned
Okay. After a short week. The code has returned.
P0172 again. One permanent stored, and one current.
any thoughts on where next?
Old Jul 26, 2018 | 08:00 PM
Did you ever check the fuel pressure?
Old Jul 26, 2018 | 08:10 PM
Possible solutions include: Inspect all vacuum and PCV hoses, replace if necessary Cleanthe MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with MAF sensor spray. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling Inspect fuel lines for cracks, leaks, or pinches Check the fuel pressure at the fuel rail Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced. Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
Read more at: https://www.obd-codes.com/p0172
Copyright OBD-Codes.com
double check that flex pipe
Old Jul 27, 2018 | 06:31 AM
  #26
I did not. What should it be at/What is the process? And can I just plug a gauge onto the rail....
Old Jul 27, 2018 | 06:33 AM
  #27
Maf has been cleaned multiple times. I'm not seeing any leak between the first 02 sensor and the engine, I've inspected that multiple times.
The car has less than 80k on it, I've inspected the vac lines in the engine compartment and see nothing. I've sprayed carb cleaner around all vac lines while running with no change in idle.
Old Jul 27, 2018 | 07:05 AM
  #28
Maybe it's time to try a new Maf sensor.
Old Jul 27, 2018 | 08:42 AM
  #29
A leak causing P0172 would be between the MAF and the #1 O2 sensor.
Fuel pressure should be 50-60 PSI, measured at the Schrader valve on the fuel rail.
You might have a bad injector.
Have you changed gas stations? Alcohol content could cause it.
Old Jul 27, 2018 | 08:55 AM
  #30
So, I need a scanner with live data......
