P0172 Code- Help Please
Old Dec 30, 2018 | 11:42 AM
  #51
Look at the fuel lines see if there’s fuel , just in front of the drivers side rear tire, mine had rotted through the vapour line. Chugging and hard starting, low 50’s fuel pressure.
After replacing the fuel lines, back to full normal, starting, no chugging, no fuel odour.
Old Dec 30, 2018 | 12:18 PM
  #52
cturboaddict's Avatar
Welllll... Right in front of the rear tire, there is a black plastic clip that holds the lines (just before the sheathing on the exhaust).
It's DAMP with fuel at the connector. I didn't poke any further with fear of making things worse.
Oh boy- now to find fuel lines I guess?
Old Dec 30, 2018 | 12:21 PM
  #53
Like this...
Old Dec 30, 2018 | 12:26 PM
  #54
So, I found a nylon replacement on Ebay?
https://www.ebay.com/itm/CHEVY-HHR-F...-/281912329600
or should I go back to steel from RockAuto, I'd have to buy the whole kit.
https://www.rockauto.com/en/moreinfo...442783&jsn=701
Old Dec 30, 2018 | 12:39 PM
  #55
If there is fuel spilling the fuel line is ruptured, the vapor line carries no liquid.
Choose whatever you think is best. I can't think of any reason to use one over the other.
Old Dec 30, 2018 | 12:48 PM
  #56
Any thoughts on the injectors after posting my fuel pressure readings? Or do you think this could be attributing to the P0172 code as well?
Old Dec 30, 2018 | 04:31 PM
  #57
53 PSI is low,
Old Dec 31, 2018 | 09:19 AM
  #58
You might just replace the fuel lines and while the tank is down replace the fuel pump.
it seems low in fuel pressure. The two birds theory.
Old Jan 5, 2019 | 09:09 AM
  #59
So, I got the fuel line replace/repaird midway up the car last night.
It runs better for sure. Startup is "better" but still chugged just a slight bit upon startup after sitting.
Is there a procedure to confirm the fuel pump is slowly dying? Starting to think I'm just "replacing" parts.
When running, it's at 60psi.
Old Jan 5, 2019 | 10:03 AM
  #60
How long does it take for the fuel pressure to pump up? I noticed my fuel pump taking longer to pump to pressure when I turned the key to on , but not to start. It should take a second or two, I changed the fuel pump , then found the fuel line leak afterwards.
