P0172 Code- Help Please
Old Jan 5, 2019 | 12:22 PM
  #61
cturboaddict's Avatar
I'll have to recheck the timing.
But last time the 53lbs was within a few seconds. Turned the key to on, heard fuel pump prime immediatley, walked to under the hood, was at 53psi
Old Jan 5, 2019 | 12:34 PM
  #62
hurst2001's Avatar
Originally Posted by cturboaddict
So, I found a nylon replacement on Ebay?
https://www.ebay.com/itm/CHEVY-HHR-F...-/281912329600
or should I go back to steel from RockAuto, I'd have to buy the whole kit.
https://www.rockauto.com/en/moreinfo...442783&jsn=701
I remember having a issue the fuel line rusting and leaking so what I did was got fuel injection hose and cutout the rusted part and cut to length and double hose clamp it and never had that problem for rest of owning it .. but that’s your choice but I never had worry about it again ..
Old Jan 8, 2019 | 06:34 AM
  #63
Just a quick update. The hard starting is still there after an evening or work shift sit. On my wife's way home last night. CEL returned with P0172.
This weekend, I will post back Fuel Pressure readings and timelines.
Old Jan 8, 2019 | 06:36 AM
  #64
Originally Posted by Oldblue
How long does it take for the fuel pressure to pump up? I noticed my fuel pump taking longer to pump to pressure when I turned the key to on , but not to start. It should take a second or two, I changed the fuel pump , then found the fuel line leak afterwards.
I should clarify my previous response to this. There is no lag between key to On and fuel pump prime activation. It's fairly immediate. I will try and check the pressure after sitting, and how long the pressure holds for.
Old Jan 8, 2019 | 08:03 AM
  #65
This is a programmed in response to many CEL situations... Don't start thinking it's a transmission problem. It very rarely is...
Old Jan 8, 2019 | 08:42 AM
  #66
I never mentioned anything about a Transmission?
Nor do I think it has anything to do with a transmission....
Old Jan 8, 2019 | 08:43 AM
  #67
Hard starting + p0172 makes me think hole in vapor recovery tube. Or the EVAP purge valve is stuck open. Hard starting might be the check valve has failed, or an air leak in the fuel tank.
It means that the ECM is correcting the A/F to make it rich. It does not mean it is running rich. Sort of the same thing, but different.
That means that there is unmetered air getting into the chamber. Most common is via the EVAP purge system. Unmeterd air would be getting in between the MAF and the #1 O2 sensor.
Ignore any transmission symptoms until the code is fixed.
Old Jan 8, 2019 | 08:51 AM
  #68
https://www.obd-codes.com/p0172
as it says, check the fuel lines.
Old Jan 8, 2019 | 09:22 AM
  #69
I've replaced both front and rear EVAP valves. The lines seemed to be okay from what I had seen. I have not mentioned any Transmission syptoms at all.... I'm not sure what you guys are talking about.
  #70
I just replaced the fuel line.
