P0302
Check the #2 injector wires.
double check the coil in #2 and the wire harness
https://www.obd-codes.com/p0302
Do I have this right? Cobalt engine, Cobalt Injectors, HHR programmed ECM.
I don't know if the crankshaft ring is the same or the cam shafts. I do know that the injectors are programmed/controlled in the ECM.
This is exactly the concern expressed in post #18. As confirmed by Oldblue, Cobalt injectors are not correct for the HHR. Whether one of the Cobalt injectors was bad is not important for now. I think you need to install the old HHR injectors. Or three new ones, in 1,3, and 4. Just get 4 HHR injectors installed. The ECM thinks it’s controlling HHR injectors. Am I missing something?
For I have the same exact issue: 2009 HHR and Flex Fuel ECM with a 2009 Cobalt engine non-Flex fuel injectors. I have the old HHR injectors in the garage and I plan on swapping them out this weekend in hopes of correcting my problems. I am getting p0171 and p0172 and some misfires as well.
This is has got to be the issue, I was just hoping to see confirmation in this thread...
Why did you use a mismatched engine? Did somebody advise that was a good idea? Did you use the old sensors with the new engine? Is it even the same size 2.2L/2.4L; I think the Cobalt only had 2.2L
They are not even the same engine, the Cobalt had a LAP 2.2L the HHR had a LE8 2.2L or LE9 2.4L
It is the ECM that adjusts the injectors based on data from the sensors. The part numbers are usually printed on the injectors.
