P0302
Old Mar 1, 2022 | 12:16 PM
Should be good, just the injectors show different part numbers, plausible they don’t play well with the other.
Old Mar 1, 2022 | 12:18 PM
So you removed the #2 injector from the HHR engine and installed it in the Cobalt engine, right? Perhaps it needs a new seal? Might have damaged it during the removal or installation?
Old Mar 1, 2022 | 12:25 PM
cfipilot's Avatar
Injectors all got new seals, I used the original cobolt injectors, I replaced the #2 injector with a new one for the hhr le8 engine after getting the codes and issues.
Old Mar 1, 2022 | 12:37 PM
Check the #2 injector wires.
double check the coil in #2 and the wire harness
https://www.obd-codes.com/p0302
Old Mar 1, 2022 | 02:22 PM
Do I have this right? Cobalt engine, Cobalt Injectors, HHR programmed ECM.
I don't know if the crankshaft ring is the same or the cam shafts. I do know that the injectors are programmed/controlled in the ECM.
Old Mar 1, 2022 | 02:25 PM
  #26
So, then the cobalt injectors should produce the code, but this code is for the hhr injector cylinder. So, I’m thinking move to the coils
Old Mar 3, 2022 | 03:40 PM
  #27
PulpFriction's Avatar
You now have two different injectors in the motor.
This is exactly the concern expressed in post #18. As confirmed by Oldblue, Cobalt injectors are not correct for the HHR. Whether one of the Cobalt injectors was bad is not important for now. I think you need to install the old HHR injectors. Or three new ones, in 1,3, and 4. Just get 4 HHR injectors installed. The ECM thinks it’s controlling HHR injectors. Am I missing something?
Old Mar 3, 2022 | 03:50 PM
  #28
Another member mentioned her misfire was addressed with new spark plug boots
From the coil pack
Old Jan 17, 2023 | 09:52 AM
  #29
#BarnMO's Avatar
What was the outcome of your injector issue, with the cobalt engine in the HHR?
For I have the same exact issue: 2009 HHR and Flex Fuel ECM with a 2009 Cobalt engine non-Flex fuel injectors. I have the old HHR injectors in the garage and I plan on swapping them out this weekend in hopes of correcting my problems. I am getting p0171 and p0172 and some misfires as well.
This is has got to be the issue, I was just hoping to see confirmation in this thread...
Old Jan 17, 2023 | 11:08 AM
  #30
Why did you use a mismatched engine? Did somebody advise that was a good idea? Did you use the old sensors with the new engine? Is it even the same size 2.2L/2.4L; I think the Cobalt only had 2.2L
They are not even the same engine, the Cobalt had a LAP 2.2L the HHR had a LE8 2.2L or LE9 2.4L
It is the ECM that adjusts the injectors based on data from the sensors. The part numbers are usually printed on the injectors.
