p0302 and p0446 related?
Old Sep 25, 2019 | 05:58 PM
Blue_SS's Avatar
Originally Posted by UnknownError
Since swapping the injectors, the code switched from P0302 to P0303. Bought new injectors and the code has not come back!
Sounds like you found it! Good work!
Misfires sometimes take a while to surface if an injector is marginal. It might only fault at higher throttle, and the fault takes multiple occurrences to get set. Your process was solid, though.
The P0446 is probably unrelated, though, right? As others have said, it's a venting issue. Checking solenoids is the start, but if your carbon canister is clogged, it can do this by itself. Also, try other pumps.
Nozzles are all over the place in their capability. When I was still at GM, we thought we had an issue with the (then) new C7 Corvette and fueling. It was just one gas station causing the concern, near Warren Tech Center, but their nozzles were junk.
Pretzel
Apr 5, 2019 07:59 AM
06burntorange
Nov 14, 2014 09:54 AM
WardRyon
May 15, 2014 04:16 AM
rotaryboy23
Sep 6, 2010 10:54 AM
Mac1958
Racing Discussion
Oct 20, 2009 10:05 AM
