P0700 code issue
Old Oct 1, 2017 | 02:38 PM
schanfam's Avatar
P0700 code issue
Hi all! Hope ing you can help a gal out... I was driving my '08 Chevy HHR (turbo?) on the interstate the other day and the cruise control just quit. When I tried to accelerate to get back up to speed, it was acting like it wouldn't shift into the final gear. As far as I could tell, it was running fine, but running at 3500-4000 RPM as opposed to 2500-3000 RPM. No check engine light, but after I made my first stop and got back into the car, there was. As it happened, I needed an oil change, and there was one next door, so my husband suggested going over there. They pulled a P0700 code, which apparently is a transmission code. After reading other threads here, can someone specifically comment on this? AND tell me if it is safe to drive...
Old Oct 1, 2017 | 02:56 PM
Welcome to the site, according to this the code means there’s something with the TCM or the transmission itself
https://www.obd-codes.com/p0700
The oil change guys code reader couldn’t communicate to the TCM to read the exact transmission code.
This code be a result of a loose TCM wire harness or ground wire
Old Oct 1, 2017 | 03:32 PM
If you don't know if it is a turbo or not; it's kind of useless having us playing 20 questions. You are not going to be able to fix it yourself.
P0700 could mean anything, it is very non-specific.
I suggest you find a good transmission shop.
George1
Nov 21, 2017 06:22 AM
Salcov
Jun 3, 2016 09:27 AM
ImNewHere
Jul 31, 2014 07:22 PM
clwest25
Jan 7, 2014 07:54 AM
JACK VICTOR
Mar 4, 2012 11:10 PM
