P0700/p0974
P0700/p0974
Good evening,
My HHR (~102k miles) was just fine on the drive to work today. Upon leaving work, check engine light came on. Took it to the Autozone, had a P0700 and a P0974 come up.
I know the P0700 is a generic TCM issue and I've been doing some research on the P0974 - it doesn't sound as scary as I first thought, but I am still a bit nervous since these relate to the transmission and I'm having visions of thousands of dollars flying out of my bank account as a result. Does anyone have any good info on the P0974 and what some of the possible outcomes might be? I plan to take it in to the shop first thing tomorrow (if the shop has room), but I'd also just feel a bit better if someone were to tell me this isn't going to make me have to mortgage the house or sell myself into slavery. :)
Thanks!
Thanks!
Are they the same transmission? I'm trying not to get my hopes up too much... I'd imagine that a solenoid replacement and filter/fluid change would be far cheaper than, say, having to replace the whole transmission...
No, they aren't the same transmission.
You might want to read this thread courtesy of the SEARCH tool at the top of the page: https://www.chevyhhr.net/forums/prob...iod-off-52595/
My father once told me that being forewarned is being fore-armed. I don't want to come off as seeming rude or snarky, not on my third post to this forum, but right now I am looking for some solid information from people who have had experiences with this issue - either mechanics who have encountered it or those with firsthand experiences - so I am better prepared to deal with the Chevy dealership's mechanics tomorrow and not get shilled for lots of money in the process.
Now, I apologize if I seem a bit snarky or rude. I'm trying not to be. But this whole thing worries me because I commute 50 miles one-way to work each day and without my car I won't have a job. Plus the whole making payments on it and possibly having to spend several thousand dollars makes me a little queasy inside.
And in the meantime, you can check the connections referred to in posts #12 and #13 in the link above. At least it gets you started on checking the possible causes you might be able to address on your own.
The P0974 code could be a result of the P0700 code
P0974 Shift Solenoid 'A' Control Circuit High | AutoCodes
States a possible result of the loose wire or harness issues.
I'd double check the TCM and ECM connections
And the ground wires, this might be the cause and is easy and inexpensive (do it yourself)
