P1174
P1174
am starting to work on my wife's 2006 2,4 HHR. I am having a few interesting issues. First I started to work on unclogging the sunroof drain lines, I think for now that problem is resolved. I also have an whining noises that is coming from the front left speakers. I disconnected the tweeter and it went straight to the mid in the door. It doesn't always have the noise when it starts if you hit a bump or press the brakes firmly it will stop some of the time. Also, I am pulling up the p1174 code on it, when I hook it to my scanner as well as a misfire in cylinder 2. Any thoughts? Thanks
It is possible that the injector is the problem but, I'd be tempted to troubleshoot the code, first, using the info in the factory service manual. It's likely that info will lead you to an injector replacement, but it's also possible it will not.
You might get lucky with one injector fixing it. Here is the bulletin on this one.
https://www.chevyhhr.net/forums/showthread.php?p=377970
BTW
to the forum justinrsetzer!
