P2135, related? Oil in ecm connector
Old Jul 6, 2017 | 01:30 PM
Php's Avatar
Php
ive been fighting the p2135 for awhile now. Car has its days sometimes it's good sometimes it messes up every 2 miles.
cleaning stuff up today.. I found that oil keeps making its way back into the ecm connector.
has anyone had this issue before? The oil in the connector.
thx
Old Jul 6, 2017 | 01:35 PM
P2135 , pertains to the throttle body or throttle pedal position sensor.
https://www.obd-codes.com/p2135
I'm not sure how you're getting oil in the ECM connection maybe a picture would help
Also engine Year and transmission
Old Jul 6, 2017 | 01:43 PM
Php's Avatar
Php
i took a pic just haven't uploaded it yet..
its a 2007, 2.2, auto car.
tb has been replaced multiple times. I ordered a new harness plug for the tb side and replaced that..
the harness leading into the ecm is about the only thing I can think of that's left
Old Jul 6, 2017 | 01:50 PM
So, same as mine 2.2 automatic 2007, why replace the TB so often ? Mines original, 388,000 klms
Old Jul 6, 2017 | 03:27 PM
The most common cause of P2135 is a bad pin in the ECM connector. Did the Darth Vader hood go missing?
Name:  Daerth Vader.PNG
Old Jul 6, 2017 | 07:36 PM
Php's Avatar
Php
I defiantly don't have a darth Vader hood on the car...
im sure it is the ecm pin(s). Just trying to make sure first..
it's just everytime I clean the ecm plug and tb plug it does just fine for x amount of time.
the tb was replaced because of the p2135 code, first it was replaced with an autoparts store brand. Didn't fix so maybe the one was defective replaced again.. Then went with an ac Delco TB l, same issues. Got another replacement just to be sure haha
Old Jul 6, 2017 | 08:23 PM
The hood keeps things like water and oil away from the computers.
Make sure all the pins are seated in the connector, check the wire side too.
I finally found the TSB 08-06-04-022B, I can't fit it here, but just put the number into GoOgle. or scan through the TSB thread https://www.chevyhhr.net/forums/prob...-thread-23231/. It even tells you which terminals to look at. The "B"on the end just means it is updated to include 2007.
Here:http://www.angelfire.com/co/ladyjarr...06-04-022A.pdf
https://www.chevyhhr.net/forums/prob...35-code-33650/
Old Jul 7, 2017 | 11:40 AM
Php's Avatar
Php
Thx man love the car just need to get this small issue fixed
Old Jul 7, 2017 | 11:45 AM
It should be in place like this just in front of the fuse box
63falcondriver
Jun 9, 2024 08:21 PM
Nazramoth
Jan 18, 2017 01:26 PM
Al Chapman
Mar 19, 2014 08:38 AM
pdmorris1
Feb 24, 2014 07:45 PM
ssjerry
Nov 27, 2013 04:29 PM
