In a panic!
Old Jul 9, 2021 | 10:33 AM
PulpFriction's Avatar
Originally Posted by TimzToyz
no I don't know it is the original battery which I don't know if this is a common problem
If you’re saying it’s the original battery, get a new one.
If you’re saying you don’t know if it’s the original battery, check if it’s an ACDelco, which is probably the original battery, so get a new one.
If a new battery is a hardship, check it out thoroughly, including charging it and then check the voltage every day for a week minimum and see if and where it stabilizes, and also load test it, and if (or more likely when) you discover it’s not holding a bare minimum, (12.7V in my opinion,) or not passing a load test, get a new battery.
lasater
Nov 25, 2015 01:45 AM
RockinD
Nov 21, 2015 07:55 AM
badassbowtie
Apr 8, 2012 06:43 AM
vschriver
Dec 8, 2008 09:12 AM
dnbguy86
Nov 16, 2006 06:18 PM
