Pass Key III
Old May 27, 2019 | 11:32 AM
Cliffs51's Avatar
Thanks! I have to wonder how many HHR's ended up in salvage yards because of this
Old May 27, 2019 | 11:49 AM
There are 2 relays on the BCM, the RAP and the HVAC; neither has anything to do with starting or running the engine. The RAP is for the windows and the HVAC runs the circulator fan.
Fuse #10 might have gotten jiggled, that has something to do with it.
Old May 27, 2019 | 01:05 PM
Cliffs51's Avatar
According to the gmpartsdirect diagram one relay is for the instrument panel, starter and the other is the fuel pump relay. Both have everything to do with the dic messages i was getting as well as the erratic panel gauge readings. I would surmise that they also affected the bcms ability to control things correctly.
Old May 27, 2019 | 02:55 PM
The BCM is the fuse panel inside the car.
One of our first suggestions was to check ALL of the fuses and relays in the under hood fuse box as well as the connection between the upper and lower halves of the box, as in this vid.
Old May 27, 2019 | 04:48 PM
Cliffs51's Avatar
Yep I should have checked that first. Im just glad I got it fixed. The added ground wire is an old school hot rodders trick 😁 Thanks for everyones help!
Old May 27, 2019 | 06:45 PM
  #26
Welcome, enjoy the ride!
wentzSS
Jun 14, 2015 07:43 PM
HillsdaleHHR
Mid East
75
Jan 2, 2009 01:03 AM
XXL
2.0L Performance Tech
Sep 1, 2008 03:05 PM
scaleguy
Mid Central
0
Jul 29, 2008 12:50 PM
