Passenger Side Blend Door Actuator
Old Dec 28, 2014 | 02:35 PM
Lucky's Avatar
The autozone web site has repair guides that can help you. I have not changed one in the hhr's but have done other models.
There are two just too the right of the gas pedal under the dash and one on the passenger side by the air bag. According to the repair guides the passenger side one requires removing the dash.
Old Apr 3, 2018 | 09:01 PM
housewiz's Avatar
Visited the Autozone website & searched videos for an HHR blend door actuator video - didn't find/see one. Do you have the link?
Old Apr 3, 2018 | 10:07 PM
It's a 3 year old thread. You are unlikely to get a response.
Old Apr 3, 2018 | 10:17 PM
Could just search youtube.
Old Apr 7, 2020 | 03:41 PM
Bonez's Avatar
Originally Posted by Oldblue
you'll need a 5.5 mm socket and a 1/4 inch drive ratchet, I just changed the one on my '03 Sunfire GT, took 10 minutes and some ackward aerobics to get my hand up there!
not on the HHR's, there is only about 1/8" of space... something has to come out and that's what Im trying to find out otherwise Ill have it done.... looks impossible.
Old Feb 21, 2021 | 01:21 AM
johnnysalinas7's Avatar
Actuator blend door
I have a chevy hhr 08 and i am having this issue with plastic part that opens and closes the actuator door. The plastic pole part broken in half. I've been told I need to remove the dash most of it. Which I think is so much work to do for a broken plastic part.
Old Feb 21, 2021 | 06:43 AM
Unfortunately, you need to remove the dash
Old Feb 21, 2021 | 10:15 AM
Do you know what the part is called?
Old Feb 21, 2021 | 11:04 AM
Look at the diagram that lucky provided above. Which actuator are you asking about, #4, #5, or #6? Then look at the part name in the lower left corner of the diagram.
Looks like the mode actuator, from your photo.
But it looks like the broken part is the larger housing? Is that correct?
Old Feb 21, 2021 | 11:12 AM
I believe it's the called hvac box
