Passenger Side Blend Door Actuator
Old Feb 21, 2021 | 01:19 PM
It looks like it might be #8.
HVAC Air Inlet Door Actuator
Part Number: 22724333
Old Feb 21, 2021 | 01:33 PM
Or the door part #11
Old Feb 21, 2021 | 01:46 PM
johnnysalinas7's Avatar
Yes it is part #11, the nipple that goes in the middle part of the actuator door. Should I just buy the whole assembly or is it possible to replace just the part?
Old Feb 21, 2021 | 01:56 PM
A used assembly would be easy to R&R just swap your working actuator motors as you know they work. Send hellshotrod a PM he might have one available and better advice about replacing that door
Old Feb 21, 2021 | 03:21 PM
I'm a new member to website how do I get a hold over hellshotrod or send a PM?
Old Feb 21, 2021 | 03:43 PM
  #26
Ok, I see it now. It looked like the post below that center hole might have been broken. With the female threads.
Old Feb 21, 2021 | 03:50 PM
  #27
Click on his name then send a PM or post your needs in here
https://www.chevyhhr.net/forums/reti...ime-buy-63306/
Old Sep 9, 2024 | 06:04 PM
  #28
Troy Lee's Avatar
Originally Posted by Deborah A
Hi. I have a 2007 HHR that makes a clicking noise for the first 5 seconds after starting it under the passenger side air bag. I have taken the glove compartment out and a person at a parts start said it was the blend door actuator. He has an 2007 HHR himself and had the same problem. It sits high up in the dash and am trying to figure the best way to get to it. So far, I have not found anything in Chilton's or by searching on line for videos or diagrams. I am looking for suggestions.
Thanks,
Deborah
Did you ever figure it out?
Old Sep 9, 2024 | 07:09 PM
  #29
Check the dates. Deborah A post was 10 years ago. She hasn’t been back here since then.
DIYGuy
Dec 24, 2021 07:05 AM
Danman03
Aug 16, 2020 12:28 PM
Bonez
Maintenance and Upkeep
37
Aug 5, 2020 08:31 PM
Chevyred2008
Jan 7, 2020 03:23 PM
mamerc
Jan 6, 2020 01:59 PM
