passenger side water hhr 2007
Hello to everyone :-) , i have water leaking from the blower motor,( like it leaks into the blower fan, and spits out through the motor seal where it is bolted ) i ve already tried every possible solution ,to no avail. i m thinking ity s coming from the heater core Butt it doesn t smell coolant at all.
is it possible that the issue is due to a heater core leak?
If you tried every possible solution what could we suggest?
When does it drip? When it rains, when the AC is on, when the Defrost is on etc.
What constitutes "every possible solution"?
Sunroof?
Is the coolant low? Check under the pressure cap.
Sunroof?
Pull out the cabin filter. I'll bet it's wet. Then do a search here for the "Butyl Patch". Since you didn't post what year your HHR is, I'm guessing it's a 2006 or early production 2007. Those were the ones that had problems with that patch.
(If asking for help, post some info. Year, model, how long you've owned it etc.)
